n3jc
- Nov 7, 2016
- 187
I am dealing with a steel canopy that is anchored to RC frame. Usually that wont be an issue but in my case I see 2 problems:
1) a bending moment from a canopy is transfered to the RC beam 300/700 mm (causing torsion on the beam) which is supported on 3 columns. In my case I dont have RC slab that is connecting RC frame to other walls (opening in a slab) so a RC frame has to deal with forces caused by a canopy - Im dealing with columns bending in both directions?
2) RC frame (3 columns + beam) is supported/anchored to RC slab (160 mm) so that means moment get transfered to a slab. Im not a fan of this. What do you guys suggest there? or am I overthinking?
