aenger
- Nov 19, 2017
- 17
I am looking for some advices on the projects I am working on now. Any input will be much appreciated.
There are two existing concrete wall on the corner as shown below. So my question is, if I connect the steel column to wall, with roof bracing, can I rely these two walls to resist wind load from both directions instead make the the steel-column system to be portal frame?
Simply put, can I use one wall on one side only to resist the whole lateral load in one direction for the structure? I mean, can I simply apply the whole lateral load on the wall in each direction to check the capacity?
Thanks in advanced.
Thanks in advanced.
