CBrech
- Aug 6, 2014
- 10
Hello-
I've read multiple threads on this subject, but I was looking for a better understanding of the factor of safety use for overturning in a footing. I've read that the .6D+.6W load combination has the 1.5 safety factor already accounted for. Below is an example I would like to use as a point of discussion and any feedback would be greatly appreciated.
Say we have a PEMB moment column and a isolated footing. The wind is producing a moment of 25 k-ft (factored) at the base. We are using the weight of the footing to resist the overturning of the moment.
Let's try a 6'x6'x3' footing at 145 pcf. So 6' * 6' * 3' * 145 pcf = 15660 lbs * .6 for Dead Load reduction = 9396 lbs.
Our resisting moment = 9396 lbs * 3' = 28188 lb-ft
28188 lb-ft / 25000 lb-ft = 1.13
My question is should I take the 25 k-ft of moment and multiply that by the 1.5 safety factor and then size a footing or size the footing the way I've shown?
