Hot insulation with zinc rich epoxy alone
nyfi
7
Can Zinc rich epoxy alone be used under hot insulation temperature range 60-80degree?
Epoxies will withstand continuous exposure to 60-80 C, and the addition of Zn won't change that. Yes, you can insulate lines coated with Zn rich epoxy if your service temperature will only be 60-80 C.
Thanks Moltenmetal,
But isn't zinc prone to formation of rusting under insulation when moisture ingress.
I would appreciate your response.
Thanks.
What if temperature is up to 120 degree continous.
120 C is marginal for an ordinary epoxy. It will be more protective than no coating, but not as protective as if it were operating cooler.
