How can I protect a small area of a large part after assembly.
freewilly
11
Hi Guys/Galls
I have a issue with protecting SG iron parts that are mated with steel (s275) parts, the assembly is then infused together as part of a GRP part (this is the product interface). We can't hold the surface flatness required for the product so we are looking at machining the area (1800mm diameter about 200mm wide) then protecting it. Any ideas?
requirements are:- Will withstand a c5 (marine) enviroment, tempuratures down to -20c, and will give a 25 year protection and won't weaken the bond between the parts and the epoxy. Did I remember to say that the products are 35m and 40m and will most likly be getting bigger.
