  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
AREMA Cooper E80 Lateral Surcharge
2457F
25
Is their a go by calculation that demonstrates the determination of lateral surchared from a Cooper E80 load and how it reduces in magnitude with depth. I believe the surcharge is determined by taking the axle load of 80kips and dividing by the product of tie length and axle spacing. However how does it reduce with depth? Trying to figure out how to apply the code to an abutment wall, no embankment at front of wall. Drilled shaft retaining walls at abutments. Thank you in advance. I'm a picture guy...fyi...so illustrations are easier to understand.
That is correct for determining the surface pressure. The Boussinesq method will give you the vertical distribution of lateral pressure.
This Union Pacific document has an example on page 18 and some charts follow that.
 https://files.engineering.com/getfile.aspx?folder=b4e650c0-b494-464e-99b3-05b6aec8e5b3&file=AREMA_-_Guidelines_for_Temporary_Shoring_.pdf
