Hi
Can you plz share what is done to avoid loads on VSD to stop/trip after a disturbance on the supply voltage?
We have several turbo-alternators + boilers connected to the national grid. Usually a disturbance on the grid causes VSD to stop/trip. We have set VSD with 3 restarts after fault, restart after power failure. But still sometimes we have some trips e.g on fans, coal feeders VSD. On compressors also we have this issue. Are there special VSD which can tackle this problem?
Whenever a critical VSD stops, the whole plant will stop. Thks
