ec2003
Chemical
- Feb 21, 2003
- 3
I'm having a little trouble understanding the following, perhaps someone here can help me out.
Nitric acid/water is an azeotropic system that has the azeotrope at ~70% HNO3 and boils at 122C, 1 atm.
Now, if you wanted to distill a 30% by wt mixture in a column to a 50% by weight mixture, you are safely underneath the azeotrope and can use simple distillation methods. However, by doing this, HNO3 is the light key (bp 84 C, 1 atm) and H2O is the heavy key (bp 100 C, 1 atm). In other words, HNO3 wants to come out in the distillate stream.
Now I have read in many places (albeit generally) that by using simple distillation as above, they are able to obtain the desired wt % HNO3 in the BOTTOMS and pure water in the DISTILLATE.
I'm confused and wonder: Just how do they accomplish this? Is there any good reference material to read online/hardcopy?
Thanks!
E
Thanks!
E
