e43u8
Chemical
- Feb 23, 2008
- 134
Dear All,
In an existing crude oil desalter there is a control configuration as follows:
A level/flow cascade control will maintain the liquid level in upstream separator while the LT/LIC is in the separator and FT/FIC is at pump discharge.
A pressure control valve (PV) is controlling the pressure of the desalter outlet line going to the stabilizer.
I'm wondering how such control configuration will work with two control system in a line? One control system maintain the level in the separator by manipulating the flow at pump discharge and another one control the pressure at desalter outlet!
Any input in this regard is highly appreciated...
