Filter Oil From Compressed Air
JeffHofacre
I need to remove 2 ppm of oil from a compressed air supply. I plan to use 10 SCFM of air which was compressed using a screw type compressor to 100 psig. The compressor size is 1000 SCFM. All 1000 SCFM of air flows through standard coalescing filters, an air dryer and then an afterfilter before entering the compressed air header. The compressor manufacturer claims the compressor only adds 2 ppm maximum oil to the air.
I am using this air to pull a sample to test for natural gas leaks (CH4) with an analyser. Oil is not good for the analyser and also may lead to faulty readings.
Will the standard coelescing filter remove the 2 ppm maximum that the screw compressors are adding to the air? I am afraid this will only remove oil droplets and not oil that has vaporized. Would an additional small activated carbon type air filter be an improvement in filtering? Is this needed?
For a critical application where you are concerned with oil vapor, I think you can use either a GAC filter or a membrane air dryer. A well-known brand is Balston (seems to be owned by Parker):
Also take a look at their 'Zero Grade' air generator for gas chromatography [under Lab Gas Generators heading]. This may be exactly your use.
You can work with 0.01 micron borosilicate glass fiber filters. (these can be used for sterile application also and are fitted with auto drain arrangement) The liquid removal rate from air is 0.1ppm. Domnick Hunter, Parker etc. are some manufacturers.
Two things to consider:[ol]
[li]A coalescing filter removes oil mist/droplets i.e. liquid, not vapor.[/li]
[li]high temperature of a screw compressor will cause the formation of carbon monoxide.Carbon Monoxide may lead to faulty readings.)[/li][/ol]
If you want to generate hydrocarbon-free air for your analyzer pass the compressed air through a potassium permanganate packed bed or a magnesium dioxide catalyst bed. Either of these will oxidize the oil vapor and the carbon monoxide present.
It may be more economical to purchase cylinders of zero-garde air from your gas supplier.
Jeff:
Rich2001 identifies the main stumbling block that most engineers trip over when they naively believe that "filters" will remove oil vapors from a compressed air or gas stream. As any experienced engineer in the compressed gas industry will confirm: No filter will remove oil vapors. A filter will remove solids readily - and maybe some liquid droplets by coalescing them. But they will not - I repeat: NOT - remove any oil vapor. Do not fall for the bull that filter guys like Parker, etc., try to feed you. There is no filtering process available to do that. Over 10 years in Air Fractionation for Oxygen, Nitrogen and Argon production taught me this. And you absolutely cannot tolerate ppms of oil in air fractionation without a firm last will & testament and a knowledge that it will be the last time you live to do that.
There is only one industrial-proven unit operation for removing oil (I'm talking total oil content, not only liquid) contamination down to 1 ppm (or less) and that is ADSORPTION. This can be done with activated carbon, but I prefer to dry my air simultaneously and therefore opt for Activated Alumina or Mol Sieves. This is done under pressure, with at least 100 psig.
I don't know whose screw compressor you're using, but beware of the oil contaminated product! If you can't tolerate oil downstream, I would never employ a screw on this service. The screw started out as a "blue sky" design in the late 1950's that was supposed to save the world by replacing the reciprocating compressor with a non-lubricated feature. After hitting a brick wall, application-wise during the 1960 -1970 era, fabricators and users finally conceded that a non-lubricated screw was only a pipe dream and the only way that the machine was going to be used industrially was to flood it with oil in order to "caulk" the inherent mechanical clearances. I've used them in ammonia refrigeration where the oil is not a terrible factor and in CO2 production and liquefaction where the oil is a strong liability issue. As in air liquefaction plants, the CO2 application also is subjected to subsequent fixed bed adsorption for mutual drying and to capture the inherent oil vapors that always are present in this type of machine. Of course, the adsorbent that captures the oil is forever poisoned and re-generation is not cost effective. So what I have always done is installed adsorbent "guard beds" in front of my adsorbent dryer unit. The adsorbent that I use for the guard bed(s) is that main dryer adsorbent that I replace on an annual basis due to aging or attrition characteristics. So I make use of what is an accepted annual waste product.
In the old days (1930-1950) Potassium Permanganate was used as an oxidant to remove the oil or hydrocarbon contaminants in the gas stream. This was a wet mess. The working solution has to be replaced from time-to-time and it is, like I say, a Holy Mess. I wouldn't recommend this type of unit operation today with the convenience of dry and available adsorbents. This is a much more effective, controllable, safer, cheaper method that effecively removes the contaminant down to less than a ppm if designed and operated correctly. For cleaning up a sample stream, much as you describe, this should be a piece of cake. I would use Activate Alumina (F-1 or H-151 grade) rather than Carbon because you can visually "see" the degree of the oil captured in the adsorbent - something you can't do with carbon. You're going to scrap the used or depleted adsorbent anyway - I doubt if you can justify regeneration. If you have other gaseous contaminants you want to remove, you can resort to more expensive Mol Sieves - which are custom-tailored for the application and the contaminants.
As a reinforcing bit of process history, bear in mind that a gas chromatograph is, in reality, nothing more than an adsorption unit. This hint tells you what the right process is.
Art Montemayor
