Steel Column Beam Joints in Parking Structures
stripez
65
Can you show examples of steel column beam joints in parking structure?
I went to this parking and noticed the joint details. The I-beam 3.2 feet (1 meter) depth and span 65 feet (20 meter) were welded as simple as this.
[image][/image]
[image][/image]
This is typical? Would you have designed this too? Imagine a few welding supports the entire spanning. This is why I'm inquiring who were the welding team who did it to strengthen the splice of a small I-beam in my project, enough to brace a wall or carry 1 meter parapet above it (no decks supporting it directly). The parking can give confidence, isn't it?
[image][/image]
They seem needlessly expensive... the first one, I'd have run the beam over the column for continuous construction, and connected it with bolts to the column, with a splice at 1/7 span roughly and framed the other one into the web with bolts... I probably would use metal pan, except for a 'throw away' form.
It is the parking of the city building officials (in charge of approving all structural plans). Just built 2 years ago. What I'm concerned with is what if repeated seismic movement would weaken the welds. And one of the giant I-beam would just fall down. I got nervous whenever i drive under it. But gave me confidence that if such small welds can support the entire giant steel and flooring. Why can't my project w8x12 I-beam splice welds support just 1 meter height of wall above or even to brace a separate wall besides it.
ductility is nice with seismic... but on a positive note, they're only civil servants... no real loss.
That isn't what I'd call simple!
A 4 way moment connection isn't typical but I seen no immediate reason to doubt the design here, I see plenty of indications that a fair bit of thought has gone into designing these connections. You seem to be under the impression that welds are weak, I'm curious on what alternative method you would use to achieve the same result without relying on welding?
As far as the question about your splice goes, as long as the welders have done their job properly then it should reach comparable strength to the parent beam. Place it away from the point of maximum design moment and you are in a more than comfortable position.
More here on full penetration splices:
But that would not achieve the same result. A 4 way moment connection.
