Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I thought headed studs are just effective for shear transfer and composite action(majorly)?dik said:I've just used headed studs... that's what they were designed for.
Can you show a sketch of what you are suggesting here, eager to know.KootK said:It might be advantageous to replace the bolts with deformed bar anchors hooked at the top around transverse anchor bars.
