R.C Column with Two layers of Reinforcement
You could have two or more layers, same as for a beam. Column from the (collapsed) Hanshin Expressway in Kobe below with 3 concentric rings of reinforcement. (I'm not suggesting that this was the reason for the collapse, by the way).
The second layer is not as effective for bending as the outer layer. It was most likely done to provide the necessary bending strength, while maintaining the required clearance between bars for consolidation of the concrete.
