Maple2
- Jul 19, 2021
- 19
Hello Gurus,
Im working on my first powerline design. I want to design a private powerline extension (120/240V single ph, 30A) from an existing breaker panel in a residence to a proposed structure 150m away via overhead wooden poles in a rocky terrain. Whats the most comprehensive way to calculate or determine the pole span and tension? I am familiar with Ruling Span Method (see attachment). However, this method is ideal for flat terrains. For those with experience in this field, what is the most convenient method of calculating or determining cable spans in unbalanced terrains?
Another issue is the proposed routes crosses a HV transmission lines at a point, hence should I go 'Direct Buried' at the location where my proposed power line crosses the HV transmission lines? EMF effect from Tx power line is a concern for me.
While faced with this dilemma, my initial choices for design are as follows:
Cable: #2AWG (Neutral supported Cable) for the connection,
Pole Class: Class 7 Pole,
wood : Western Red Cedar
Length: 25 ft
Minimum Top Circumference: 15 inches
Min. Circumference at 6ft from butt: 24 inches
Your opinions would be appreciated. Thank you
Length: 25 ft
