I am using STM for this offset column to flat slab analysis and design and wondering how to design to this vertical tie? If I use one way shear Vu will not be sufficient so I have to use vertical ties. However it doesn't convince me that I need vertical tie here. The reason being, if the column above does not overlap with the one below, the punching shear capacity from the concrete can take this transfer load (say 1500kN) without using ties. Thoughts?
