Hello - apologies in advance if this is not the correct thread.
I am looking into designing tapered insulation on a flat roof that requires sumps for internal drains. My understanding is that the area around the drain needs to be a 4 ft x 4 ft area with a 4 way slope into the drain at a 1/4:12 slope. Is this specified in the code somewhere or is there a standard for this? I am not able to find reference to it.
Thank you.
Thank you.
