nivoo_boss
- Jul 15, 2021
- 132
Hey everyone!
So I have to design a slab foundation for a loading dock shelter (light steel structure). It will be cast on gravel. My question is, should I put insulation under the slab? I’ve seen pictures like below where there is for example 100 mm of EPS under the slab. But since it does not reach out below the slab, it does not seem to help much in case of frost heaving – why use it then?
I’m thinking about ditching the insulation. The structure is light and the slab is on gravel which should not be too sensitive to frost heaving. And even if it is, some deformations here and there should not do much to the light and flexible steel structure that the slab is supporting.
What are your thoughts on the topic?
