geesaman.d
I'm trying to study the vibration of a machine with antifriction bearings (mostly taper roller) that generally lives 5+ years before reaching rolling surface fatigue failure. Unfortunately I may not have a set of suitably worn bearings to harvest for this test study.
Is there a relatively valid way to accelerate it? I've considered indenting the rolling surfaces on the bench using sandpaper and a peen hammer, or preloading them heavily to make them wear within the time of my testing.
Another question: for taper roller bearings that are set slightly loose (say .003" factory endplay), how much additional endplay is reasonable to simulate bearings that have lost material to rolling surface fatigue?
David
David
