Standard Designation: BPV Section VIII Div 1
Edition/Addenda:
Para./Fig./Table No:
Subject Description: Section VIII, Division 1 (1998 Edition, 2000 Addenda); UG-34 and UG-39
Date Issued: 12/07/2001
Record Number: BC01-336
Interpretation Number : VIII-1-01-105
Question(s) and Reply(ies):
Question: A circular blind flange, used as an unstayed flat head, has a nozzle attached at its center using a full penetration weld, or a partial penetration weld, or a screwed connection. Are reinforcement calculations per UG-39 of Section VIII, Division 1 required for this geometry if the opening in the blind flange is of a size that is permitted in the flange standard referenced in UG-34(c)(1)?
Reply: No.
Edition/Addenda:
Subject Description: UG-34 and UG-39, Blind Flange Thickness
Date Issued: 01/05/2009
Record Number: 08-1562
Interpretation Number : VIII-1-07-69
Question: If an opening in a blind flange is greater than that allowed by provisions of ASME B16.5, is it required to use UG-34(c)(2) and UG-39 to determine the required thickness and reinforcement in lieu of the dimensions and pressure ratings that are given in B16.5?
Reply: Yes.
Edition/Addenda: 2015
Para./Fig./Table No: UG-36(c)(3) & UG-39
Subject Description: Reinforcement of Openings in Standard Blind Flanges
Date Issued: 04/02/2019
Record Number: 17-2457
Interpretation Number : BPV VIII-1-19-05
Question 1: An ASME B16.5 or B16.47 blind flange has openings that do not exceed the size and spacing limits in UG-36(c)(3) and do not exceed one-fourth the head diameter or shortest span. Is it acceptable for Section VIII, Division 1 construction to use the ASME B16.5 or B16.47 pressure-temperature ratings for this blind flange without performing any additional design calculations?
Reply 1: No
Question 2: An ASME B16.5 blind flange has an axial hole in the center. The hole size exceeds the size limits in UG-36(c)(3), but is permitted for a blind flange used as a reducing flange per ASME B16.5. Is it acceptable for Section VIII, Division 1 construction to use the ASME B16.5 pressure-temperature ratings for this flange without performing any additional design calculations?
Reply 2: Yes
Question 3: An ASME B16.5 reducing flange requiring a hub has an axial hole in the center that exceeds the size limits in UG-36(c)(3). Is it acceptable for Section VIII, Division 1 construction to use the ASME B16.5 pressure-temperature ratings for this flange without performing the reinforcement calculation per UG-39?
Reply 3: Yes
