Otter
- Oct 30, 2001
- 12
I am in search of an SAE D pad hydraulic pump disconnect.
I have a pump drive with multiple output pads. I need to be able to disconnect the drive shaft of a single pump.
I am looking for a manual disconnect unit to mount between the pumpdrive output pad and the hydraulic pump. The pump mounting pad is an SAE D pad.
The unit could be constructed utilizing a shifting fork and sliding intermediate splined shaft. I am looking for a low profile unit, the pump can mot be cantilevered off of the pump pad by more than 6 inches.
