durga_k
- Jun 13, 2023
- 1
Hi All,
Trying to use accoreconsole.exe for batch publishing of .dwg file to .pdf
The script is running fine, however the issue I'm facing is, it generates a prefix to every pdf generated. Eg 56GF-Model.pdf
The ideal condition should be 56GF.dwg to 56GF.pdf.
Attached is the .scr which I'm using.
Any suggestion thanks in advance
