Nominal thickness for flanged valve(For ASME B31.3 impact curve)
ipi
Petroleum
Nov 24, 2004
25
Hello there,
For a flanged valve say 4" #600 Flange RF, What is the nominal thickness value to be used for impact requirement curve . Material is A216 WCB(Casting)
is there any table where i can find the nominal thickness of flanged valve for a given material?
Does the minimum shell thickness of the valve has any role in determining nominal thickens of valve?
WCB doesn't have a curve (letter designation), limit is given as -20F for all thicknesses.
ASME B16.34
*** Per ISO-4126, the generic term
'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
