MTNClimber
Geotechnical
- Jul 24, 2018
- 660
Is there any published guidance as to the minimum strength of grout for drilled micropile and lagging walls (fully cased piles)? I’ve seen 4000 psi in the past, which seems overkill.
We always spec 100 psi CLSM for drilled SPL. I’m guessing traditional flow fill CLSM might be difficult to pump through a 1” tremie.
