IanVG
- Jan 21, 2022
- 74
Hey everyone,
I've got a question about a piece of code from the 2018 International Mechanical Code (IMC). Section 510.6.5 states for makeup air for hazardous exhaust systems that:
Makeup air shall be provided at a rate approximately equal to the rate that air is exhausted by the hazardous exhaust system. Makeup air intakes shall be located in accordance with Section 401.4.
In addition section 501.4 on pressure equalization states that:
Mechanical exhaust systems shall be sized to remove the quantity of air required by this chapter to be exhausted. The system shall operate when air is required to be exhausted. Where mechanical exhaust is required in a room or space in other than occupancies in Group R-3 and dwelling units in Group R-2, such space shall be maintained with a neutral or negative pressure. If a greater quantity of air is supplied by a mechanical ventilating supply system than is removed by a mechanical exhaust for a room, adequate means shall be provided for the natural or mechanical exhaust of the excess air supplied. If only a mechanical exhaust system is installed for a room or if a greater quantity of air is removed by a mechanical exhaust system than is supplied by a mechanical ventilating supply system for a room, adequate makeup air shall be provided to satisfy the deficiency.
I thought that good practice concerning exhaust systems is to maintain relative negative pressure relative to spaces where the relevant air-borne hazards are lesser. When I read that makeup air shall be provided at an approximately equal rate that air is exhausted, I am not sure how it is possible to keep a space both relatively negative and where makeup air equals exhaust air. The only other way I see this making sense, is if the makeup air enters the space through an indirect system, e.g. makeup air infiltration through transfer ductwork, or through/under doors. With that interpretation you could practically rewrite section 510.6.5 to simply that "Think about where and how your air is entering your space." Any thoughts?
