Do you know any metallography etching data base?
Soldador
Materials
Nov 21, 2002
13
Does anybody know a metallography etching web site ?
I am trying to etch a dissimilar welding (monel-304L). I have already tried cromic, nitric-hydrocloric-acetic, nitric-acetic,and oxalic. but the results were not good. Some of them preferencialy attack the grain boundary or the interdentritic zones. Therefore the microstructure is not clearly developed.
please, could anybody help me?
Thank You.
is a good website for this type of information. Check the archives or post a new question. Experts from Struers and Buehler frequently reply here, so I highly recommend you check it out.
Have you tried electropolishing? Phosphoric acid (H3PO4) in glycerol and water is used for both of these alloys. The current density recommendation in ASM HANDBOOK Volume 3 Metallography and Microstructures is a little different, but you may find it useful:
solution:
37 mL H3PO4
56 mL glycerol
7 mL water
For stainless steel, the recommendation is 0.78 A/cm2 at 100-120 C for 5-10 minutes. For monel, the recommendation is 0.9-1.0 A/cm2. Good luck.
