Manufacturing Process
DesEngineer4
181
What are the different manufacturing processes that can be considered for a Helicopter fuselage engine access door? Kindly Suggest!
Thanks & Regards
well, that depends.
maybe you should answer all of the questions that were asked in the other post you created on this subject.
Sure, here are the details:
Fire containment required - YES
Operating vibration/noise/sonic and air-loads environment? - Pushing Out
Upper, side or lower location - Major part to Lower and some to the Side (it's side and lower)
Expected abuse or maintenance loading, IE: wind? maintenance - As of now NO data
Does the door have louver or screen air vents - NO
Door hinge and thumb-latching... or... panel fasteners [quick-turn] all-around - Hinge & Latch Mechanism
How many aircraft do You intend to install this door on, IE: 1 or 1000? - Max 5 - 10
Private use? Civil use? Military use? - Private Use
Thanks & Regards
@IRStuff - Sorry about that
@SWComposites - Please have a look at the above answers for your questions and please share your thoughts
Thanks & Regards
The need to be a fire barrier probably rules out composites, though it depends on the specific fire regulations and requirements that need to be complied with.
Also, the low number of aircraft also probably rules out composites due to tooling costs.
So a metal design is probably appropriate. Machined frames/stiffeners riveted to sheet metal skin would likely be first choice. Material selection probably depends on fire requirements.
Thank You for your response.
I found few images in google, any idea how they might be formed/constructed. I'm very interested to know about 1st image (Engine Bay-1). I didnt see any support frames for this type. How that would be possible? OR was structural frame covered with a thin sheet?
And for second image, I can see some semi structure frame and other part is covered again.
Please suggest.
Thanks & Regards
Sorry, I’m not opening a zip file from the internet. Please embed the pictures directly into a post here.
