Ptc Creo Parametric problem.Need help
mardarko
Industrial
Nov 26, 2023
5
Anyone knows why in creo parametric cutted profile in framework(afx) can not be seen in drawings as in part.
Another words ,the whole profile is shown along with cutted piece.
Must be adjustment in config file but,i can not find it.
To create cut parts in assemblies Creo creates a hidden family table that is usually stored in the assembly file. To show the cut part on the drawing it needs to be in the assembly.
Per the help files:
1. On the Framework tab, click Drawing Tools > Create accumulative dimensions. The Drawing Creation Options dialog box opens.
2.Select Create part drawings to create single part drawings.
Hidden line removal doesn't work correctly on parts that interfere.
If that's not the problem, try uploading a much simpler case as an example.
I don't have access to the software, so will need to see just the pictures.
If you could, describe which part and what you mean by "profile"
For me profile would be the sketch of the cut, but I saw the square extrusions were all the same length and did not look cut in the assembly.
It's the square tube 50x50x2 from the framework.But I tried in Creo 10 ,it's ok.There is no problem.Thanks for trying.
