One way bearing for filament retraction
ScrewYouGravity
Aerospace
Jul 25, 2023
4
Hi everyone,
I am currently working on an upgrade to a 3D printer filament spool holder. I have been looking for a passive system which allows the free turning of a spool in one direction and engages is with a motor in the other direction.
I have experimented with one way bearings however I have only been able to come up with a system where the motor does not engage when activated as it is in the same "free wheel" direction as the spool. Does anyone have an example of a design which does this and allows you to engage the motor in the direction opposite to the required freewheeling direction?
Thank you for your help!
What is an acceptable torque for "free-wheeling"? Will a slip clutch which has equal torque in either direction work for your application? The clutch can also be turned-off to free-wheel.
Thanks all for your replies.
The free-wheeling resistance has to be very low to avoid causing issues in the print. An active slip clutch or magnetic clutch would work to engage/disengage the motor, I was just wondering whether there was a passive solution I hadn't yet discovered.
Unfortunately the powered direction is opposed to that of a bicycle free-wheel. I will keep investigating miniature clutches to find the best option. Thank you!
Reversing the direction the filament spool is loaded will reverse the action needed from a freewheel; similarly, changing which side of the freewheel is fixed reverses the freewheel action. Finally, adding an idler will reverse the action.
