Generator is not starting - Volvo Penta Engine
Thiago Mendes
BR
Hi!
I was requested to troubleshooting a genset composed of Comap InteliGen-NT controler and Volvo Penta TWD1644GE engine which is not startig, either in auto or manual mode. When I gave a command to start the dysplay just blink followed by "WRN ECU" alarm.
All CAN connections and controller parameters have been checked with no abnormalities.
Have you guys experienced similar issue?
Probably you will need to be more specific. The engine is not turning over at all, or it isn't starting? Sounds like it isn't turning over or attempting to start at all?
Has the ECU been replaced?
Has anything been replaced recently?
Ohm's law
Not just a good idea;
It's the LAW!
Is it even getting a start signal?
When one this sentence into the German to translate wanted, would one the fact exploit, that the word order and the punctuation already with the German conventions agree.
-- Douglas Hofstadter, Jan 1982
This may give some insight into some German schematics that I have encountered, without actually imparting understanding.
Ohm's law
It's the LAW!
Your battery is dead.
Put your multimeter on it. While the the starter is engaged you'll likely see the battery voltage drop below 9 volts for a 12v system or 18v for a 24 system.
It's frustrating that nobody considers the box full of acid to be the most likely component to have problems in an engine starting system.
Possibly . . .
However, despite dpc's request, OP has not yet stated precisely what's or what's not happening during starting attempts, viz., is engine not cranking at all?
Is solenoid even engaging starter?
Is it that cranking is sluggish?
Or is cranking healthy but engine just not firing at all?
Or is engine sputtering and firing a bit, but just not catching?
Saying what the error code is, if any, is helpful, but doesn't tell the complete story; it's difficult for anyone to assist you with diagnosing something if only partial or incomplete details are provided.
As has been stated here repeatedly, more information yields better answers.
Your turn, Thiago.
CR
OP has said everything that needed to be said. The display blinking indicates it is losing power. The "WRN ECU" alarm indicates the can nus link is being interrupted due to loss of power.
