rollingcloud
Aerospace
- Aug 9, 2022
- 172
I have a .25 - 28 UNJF nut made of G87400 that was tested per NASM1312-8, the hardness measured 22 HRC, it failed the tensile test (requires 4590 lbs of tensile load, nut threads stripped. Is it correct to say that the fixture setup used in NASM1312-8 tensile tests focuses on the tensile strength of the fastener itself, making the length of thread engagement not a factor in the tensile strength value determined by the test, and therefore, the result is a measure of the inherent strength of the fastener material and the stress area, not the joint (nut + bolt) strength?
I mean it makes sense when testing a bolt, because the location of failure would most likely be outside of the thread engagement area. But when testing a nut, the location of failure is inside of the thread engagement area.
I was assuming the length thread engagement would be a factor in the stress area of the fastener during an axial tensile test, before reading into the NAS spec. But I am still not sure how a fixture could make the length of thread engagement irreverent in determining the tensile strength. When the nut and the bolt mates properly, it would be a full engagement.
