Air Conditioner outdoor unit leaking refridgerant
Dodgyemail
1
I’m after some advice regarding my parents 22 year old Actron Ducted Aircon, which has lost most of the R22 Gas. The unit works fine and has been a great aircon…but over the years has leaked 80% of the R22 gas. The Technician came out and identified 3 leaks, which were in the: Accumulator, Reverse valve and a Brass Connection Point. Photos attached.
Quote to repair was in the thousands and my parents can not afford that. I would like to see how to get it working using a proprietary leak seal injection for refrigerant gas.
These products seem to (from my limited knowledge) work fine for copper pipes, but I’m[pre][/pre] not sure about using this product on the Accumulator, Reverse valve and Brass connection point.Therefore I would appreciate any advice before I buy a Leak seal product, so I can work out if its worth it.If we can get say another 3 to 5 years from the air con, that would be great.
INFO: 22Kw Ducted Actron. Currently uses R22gas, but seeking alternative substitute gas (perhaps R417A). Location is Brisbane Australia with January maximum being in Mid 30degrees celcius.
Appreciate the help
