CAESAR II : How to include piping files with relative path ?
RadiateurFou
Industrial
Feb 12, 2024
34
My CAESAR II include the full path of my piping file, instead of just the relative path (see image) :
The first two files have correct relative path, but the last one which I personnally included is taking the full path.
How can i include files like the first two?
Thanks in advance
I'm not sure what your screenshot is showing. Generally I drop the PCF file into the project folder I'm working in, point to it during the import process, and everything's fine.
It's possible C2 doesn't like network links and/or you're mixing up a link someone sent you (with their user name info as SharePoint and ACC tend to do) and this won't work on your computer.
My screenshot is showing the table of "piping include file" in CAESAR. The first two links are good, it shows only the relative path. But the last one as you can see the CASAR is showing the ful :/:/:/ path.
You drop the PFC file, not the C2 file?
"TELETRAVAIL" translates to "distance work"; is it possible this file is on a remote server intended for work-from-home?
This is confusing but no, it's just the name of the folder where we put all of our files
Sounds like you need to submit a helpdesk ticket to Hexagon
did you try with a folder name without les accents?
best regards
Yes aha les accents weren't the problem. However i found a solution that works partially, i can delete in the include piping files all the path that i'm not interested in and just keep the relative path. It then stays with the relative path
