CNSTR WAWRNING IN ETABS
Surinder_singh
1
Can anybody tell me about this problem i am getting ill conditioned in my model and getting warning of CNSTR , if i am going to the coordinate there is only slab no clear point even after deleting slab , problem is not solving please, kindly anybody help me
TYPE LABEL DOF X-COORD Y-COORD Z-COORD PROBLEM VALUE
Cnstr U1 11910 16822 4572 lost accuracy 7.9 digit
Please someone answer to this problem
Examine the constraints in your model to ensure they are properly defined and not overly restrictive. Sometimes, constraints can inadvertently lead to ill-conditioning if they are too rigid or conflicting. You may also need to Verify the quality of your input data, including the coordinates and other parameters used in your model. Ensure that there are no errors or inconsistencies in the data that could contribute to numerical instability.
