Doubt about GENERATOR technical drawing 1
First thoughts:
1. the view shown is an isometric, often used to show general details, not specifics. For these you need to to see the traditional Orthographic Views (google it.)
2. I suspect that the letters are not from Engish, but looking at the generator, i suspect they mean:
drive end (where the turbine will go)
non drive end / exciter end
Or grid lines showing the placement on a larger print.
Ohm's law
Not just a good idea;
It's the LAW!
TS/TE = turbine (prime mover) side.
ES/EE = exciter (not prime mover) side.
Could just as easily have been called DE (drive end = prime mover end), and ODE (opposite drive end). Or, in the case of one particular manufacturer, REAR (prime mover) and FRONT (furthest from prime mover) ends.
Converting energy to motion for more than half a century
