Calculate Load Power Cunsumption using PMU measurements 1
Balaji TS
3
I am working a load measurment task. I have a bus connected with loads and we have a PMU unit connected to bus for measuring the phasor and frequency data. We are getting Voltage Magnitude, Voltage PhaseAngle,Current Magnitude, Current PhaseAngle, Frequency and ROCOF data from the PMU. All 3 Phase Voltage and Current measurements we are getting. So is there any way we can calculate the downstream load consumption using the PMU measurments?
or can we check if the loads consuming more power or not using PMU measurements?
Please help me with a solution for the same.
Thank You.
Balaji
Asked and answered in thread238-517556.
When one this sentence into the German to translate wanted, would one the fact exploit, that the word order and the punctuation already with the German conventions agree.
-- Douglas Hofstadter, Jan 1982
