green cone on the pipe 1
ChristianQR
Materials
Apr 10, 2024
Hello
Does anyone know what this green cone on the pipe is? The code is Cesaer but i don't have acces to the real model. The pipe must be buried, but I'm not sure if this is equivalent to ground springs.
Give us a clue....
Which program?
What does it say when you click on it?
Have you asked anyone?
This looks like Caesar II. That appears to be a flange that had its thickness reduced in the program - seemingly to imply its no longer there?
If its Caesar II it's definitely not ground springs or anything like that. It would be a "rigid" which can be used to represent anything non-flexible in terms of piping (flanges, valves, etc).
Thanks, th ecode is Cesaer II but i don't have the acces to the model.
