Danlap
- Sep 17, 2013
- 313
Good day valve expert,
In need for super ball valve which have the capability to handle slurry and/or already have proven record of passing API 6AV1 Class III Sand Slurry testing.
Our product is Naphtha in carbon steel pipeline hence corrosion rate is quite high. Nonetheless ball valve PIG-able still preferred over through conduit gate valve.
Is there any ball valve with 'scrapping' capability as indicated above?
Thank you,
Kind regards,
D
Thank you,
Kind regards,
D
