B31.1 change to occasional design loads
KevinNZ
NZ
ASME is planning a change to B31. (also B31E & B31.3)
proposed change clause 101.5.2 and 101.5.3. ".. the Allowable Stress Design reduction factor shall not be applied”.
The following is the ASME explanation provided for the item record associated with this revision:
“Some time ago the American Institute of Steel Construction (AISC) and the structural steel industry reduced the allowable stress multiplier of 1.33 to 1.00 for occasional loads such wind or earthquake in concert with moving to strength design methods. The ASME is based on working stress design methods and not strength design methods. The ASCE recognizing that many structural designers still use allowable stress design methods (comparable to ASME’s working stress design methods) adjusted the seismic demand (earthquake force) in the seismic nonstructural components chapter (where B31 is referenced) by multiplying the seismic demand by 0.7 (roughly 1.00/1.33), ostensibly to compensate for the difference in strength design methods and working stress design methods. Further, the same adjustment in the ASCE seismic requirements is inferred in the ASCE wind requirements. Since B31.1 allows the occasional load increase for piping, there is no reason an occasional load increase should not be allowed for structural steel supports.
However, it was pointed out that what was proposed would result in [highlight #FCE94F]double dipping, reducing the load by a 0.7 factor per the ASCE 7 and increasing the allowable per B31.1[/highlight]. I agreed, stating the reference to ASCE 7 for earthquake loads would be augmented by not allowing the Allowable Stress Design factor to be used when developing loads for supplementary structural steel and permitting the occasional load allowable, 1.2Sh, to be used. The ASCE 7 reference for wind loads will similarly be augmented.”
Further, the following is some commentary from the project manager of this item:
“The B31.1 seismic requirement is consistent with the AISC's and ASCE 7's consideration of Allowable Stress Design (and ASME's working stress design) methods. Both B31E and B31.3 are considering whether to conform to B31.1. However, B31E-2010a has lost ANSI approval and the current B31E activity intent is to develop a new standard to incorporate the latest understanding of the seismic failure mechanism of B31 piping which correlates better with fatigue rather than collapse (collapse being the failure mechanism expected by the civil/structural discipline). Further, the civil/structural discipline recognizes the superior performance of B31 piping compared to piping designed to other standards. ASCE 7 reflects this understanding (but currently fails to appropriately compensate for piping support loads and displacements). Finally, the B31E activity realizes that the current design methods of the B31 Books and probably the design methods employed in other countries are overly conservative but B31E has no rational justification to abridge the AISC and ASCE 7 requirements.”
Note this explanation and commentary is being provided for information and should not be considered an official response from the Committee or ASME. .. or if you would like further information or like an official response from the ASME B31.1 Section Committee.
Draft change can be found here
I would say a change to working stress factor for EQ design needs to go hand in hand with conformation of the Rp and ap values to use for the piping loading. ASCE has assumed Rp and ap based the robustness of B31 design. If removing working stress factor makes the design more robust then Rp and ap could/should change
This is what I submitted on the change.
In regards to proposed change B31.1 clause 101.5.2 and 101.5.3.
“Structures, except the Allowable Stress Design reduction factor shall not be applied”.
I agree there is a case for “double dipping” with the Allowable Stress Design reduction factor and K values for occasional loads.
But for earthquake loads there is currently no “double dipping”. the method used for calculating the seismic loads applied to the piping model already accounts for this issue. For example, in ASCE the Rp values for piping is directly related to the use of B31.1 (&B31.3) in the current form with the K values and Allowable Stress Design reduction factor applied to the loading cases. The same for the Rp value in B31E. If the Allowable Stress Design reduction factor is removed the Rp values will not be correct.
Very confusing where ASCE and B31E treats B31.1 and B31.3 the same, this proposed change makes the codes different.
Here in New Zealand, we do not use ASCE but have developed national rules that treat B31.1 and the B31.3 piping the same and use seismic loading factors that assume Allowable Stress Design reduction factor applies to the load combinations.
Were the above change to apply we would need to still need apply a correction for removing the Stress Design reduction factor. For example 1/Rp * 0.7.
For wind loading I agree with removing Allowable Stress Design reduction factor.
The codes are never the same. They would need only one.
No way would that ever make sense. [slight sarcasm]
