Force on Temporary Polywall
Engineery007
1
I have a CAE that needs to maintain a 0.04"WC DP across a temporary poly-wall divider while construction is being done. I need to calculate the lbs of force per square foot so I know if this is possible. The wall will be 122'Lx10'H. I think this is a simply P=F/A but what I am coming up with doesn't make sense.
What are you coming up with?
Here is what I get:
1 psi = 27.78 "WC
so, 1" WC = 1/27.78 psi
so, 0.04" WC = 0.04/27.78 psi, which is 0.00144 psi.
Multiply by 144 to get psf. 0.00144 x 144 = 0.2073 psf
