DiaeArrahmane
Automotive
Hello, let the yellow arc be the surface I want to offset, and the red box be the limit (cannot be modified). Is it possible to offset the arc with a constant default value, and decrease it locally in order to get a variant offset something like the pink shape. Is there a way to do so using macros? Like using a function to avoid any clash with other parts? or something like a loop that goes along an axis with a constant step, and decide the offset(between 0 and the default value) based on the constraints?
Any thoughts guys?
Any thoughts guys?
