System Protection
- Apr 13, 2023
- 55
I ran across this paper on dealing with CCVT transients.
[URL unfurl="true"]https://na.eventscloud.com/file_uploads/96d444004fb61dbb6c16cf985e94906d_PSE_CCVT_Transient_Investigation_2016.pdf[/url]
They saw a decrease in magnitude of the transients at the test switches after replacing the spark gaps.
Has anyone else noticed this? Should spark gaps be maintained when PLC is not in use?
I'm sure proper shielding would make the most difference here. Interesting though.
