SteveV60
Automotive
- May 9, 2024
- 1
I am trying to get an idea of cylinder pressures when the piston has finished its power stroke. The pressure prior to blow down of the exhaust valve opening. I have read from a source that pressures can vary from 50 to 200 psi. I am trying to confirm and look for alternate sources to verify as I am building a blow down flow bench for exhaust port & valve testing. Diesel and gas, including 2 storke diesel pressures would be ideal.
Any help appreciated. Thanks - Steve
