michaely
- May 24, 2024
- 1
I have an interesting question here...
I have a cylinder with internal leak. Assuming both sides of the cylinder has no applied force and equal pressure on both the piston and rod side. The cylinder is also placed on a horizontal orientation. Will the cylinder extend/retract/have any movement due to the internal leak?
Thanks in advance!
Thanks in advance!
