Catia V5 VBA MACRO:use GetMeasurable to get coordinate of points from CATPart to CATDrawing
Blackmamba24
Automotive
TW
I really need some help with my macro code
I’m trying to write a macro that can retrieve the coordinates of points from a CATPart and generate a table in a CATDrawing, similar to the “Coordinate Dimension Table” function.
However, my code is stuck at this line with an error:
Run-time error '13':type mismatch
Code:
[highlight red]Set TheMeasurable = TheSPAWorkbench.GetMeasurable(selPoint(n))[/highlight]
So i added a msgbox to display the type of the selected points:
Code:
MsgBox selPoint(n).Name
It turns out that no matter how i select points in the drawing view, all the selections are "view", not "point"
Are there any tips for selecting "the actual point" in the drawing view, or for extracting coordinate of points from CATPart to CATDrawing?
Any help would be very appreciated.
Code:
Sub CATmain()
        Dim myDoc As DrawingDocument                'selection and table
            Set myDoc = CATIA.ActiveDocument
        Dim mySheet As DrawingSheet
            Set mySheet = myDoc.Sheets.ActiveSheet
        Dim myView As DrawingView
            Set myView = mySheet.Views.ActiveView
        Dim drawingViewGenerativeBehavior1 As DrawingViewGenerativeBehavior
            Set drawingViewGenerativeBehavior1 = myView.GenerativeBehavior
         drawingViewGenerativeBehavior1.ColorInheritanceMode = cat3DColorInheritanceModeOn
         drawingViewGenerativeBehavior1.ForceUpdate
        Dim selection1 As Selection
            Set selection1 = CATIA.ActiveDocument.Selection
        selection1.Search "Color='(255,0,255)',all"
        numberOfPoints = selection1.Count
        Dim MyTable As DrawingTable
            Set MyTable = myView.Tables.Add(100, 100, numberOfPoints + 2, 5, 7.5, 20)
        MyTable.SetCellString 1, 1, "tube length="
        MyTable.SetCellString 2, 1, "POINT"
        MyTable.SetCellString 2, 2, "X"
        MyTable.SetCellString 2, 3, "Y"
        MyTable.SetCellString 2, 4, "Z"
        MyTable.SetCellString 2, 5, "R"
        MyTable.MergeCells 1, 1, 1, 5
        MyTable.SetCellAlignment 1, 1, CatTableTopCenter
    Dim n As Integer
    For n = 1 To numberOfPoints                 'extract coordinate of points
        ReDim selPoint(n)
        Set selPoint(n) = selection1.Item(n).Value
        'MsgBox selPoint(n).Name
        Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") ' set TheSPAWorkbench
        [COLOR=red]Set TheMeasurable = TheSPAWorkbench.GetMeasurable(selPoint(n))[/color]             ' set Measurable with reference
        Dim coords(2)
        TheMeasurable.GetPoint coords              ' get coordinates from Measurable
                'add point name
                MyTable.SetCellString 2 + n, 1, letter & n
                    xPoint = Round(coords(0), 1) 'check decimals
                        If Int(xPoint) / xPoint = 1 Then        'check if integer
                            MyTable.SetCellString 2 + n, 2, xPoint & ",0"       'add ",0"
                        Else
                            MyTable.SetCellString 2 + n, 2, Round(coords(0), 1)     'else, use 1 decimal
                        End If
                    yPoint = Round(coords(1), 1)
                        If Int(yPoint) / yPoint = 1 Then
                            MyTable.SetCellString 2 + n, 3, yPoint & ",0"
                        Else
                            MyTable.SetCellString 2 + n, 3, Round(coords(1), 1)
                        End If
                    zPoint = Round(coords(2), 1)
                        If Int(zPoint) / zPoint = 1 Then
                            MyTable.SetCellString 2 + n, 4, zPoint & ",0"
                        Else
                            MyTable.SetCellString 2 + n, 4, Round(coords(2), 1)
                        End If
    Next
        selection1.Clear
        MsgBox "Coordinate dimension table created!"
End Sub
I found that selecting the points in CATPart and switching back to CATDrawing, the issue could be solve.
Code:
 Set PartDoc = myView.GenerativeBehavior.Document.Parent
        PartDoc.Activate
You're welcome. me from two weeks ago.
