Suhanda Ambari Harun
Dear All,
Could you please help me, as I'm going to design metal to metal seal for tubing hanger for Wellhead and X-Mas Tree. The MTM seal should able to be implemented under temperature class U (maximum 250 degree Fahrenheit) and under external pressure 10,000 psi. So, the material chosen as per analysis result is 17-4-PH stainless steel with 105,000 psi yield strength. The thing is this metal seal will sit in the tubing hanger with 410 stainless steel material 80,000 psi yield strength. The question is what is the effect of 17-4-PH material relative to 410 stainless steel in term of its application and installation? Will 17-4-PH damage the tubing hanger 410 stainless steel as the hardness of 17-4-PH is higher than 410?
Thank you in advance.
