Triad Size
cobra46
75
I Googled and searched here and couldn't find anything.
Does anyone know if it's possible to increase the size of the triad that's down in the corner. I want to use that to identify axis directions in a report I'm making.
The triad shows X, Y and Z directions clearly in isometric, dimetric and trimetric views. May be you need to elaborate exactly what you are after. I presume you want to include a screen shot in your report. Give us more light of your intentions.
DD24
@DD24
The red, green, and blue triad in the corner is very small in relation to the size of the screen. If I do a screen capture of it to place next to a model, it is very small. I would like to make it a bit larger to make the axis directions more clear. A screen capture of this triad is only about 60 pixels square.
I hope this makes sense.
Hie Cobra46
I have tried to look for any information on resizing the reference triad, I have not found any.All whats there is turning it on and off.
DD24
