Industrial practices in CAD modeling of machined parts 1
faerosp
Aerospace
Jun 27, 2024
4
Dear all,
I am looking for information regarding the methodological aspects of the modeling process with CAD softwares, particularly in the aerospace industry. I used mostly CATIA but my questions are not software-specific and I am also interested to read advices from people using other softwares such as NX, Creo, Solidworks, etc.
At the moment I am focusing my searches on strategies for modeling machined parts. Sadly I am afraid most of this knowledge and experience remains inside companies, for reasons I can understand. It is indeed very hard to find practical insights: most papers I found are often excessively academical and lack the details of industrial practices.
The most common approach I have seen so far, especially with CATIA, is to use a “design by machining features” multi-body approach. The part is modeled the same way it will be machined: starting with a body representing the blank part then subtracting through Boolean operations bodies representing machining volumes (the volumes of materials the milling cutter tool will remove). The floor and walls fillets of each pocket (caused by the cutter tool geometry) are modeled on the machining bodies instead of being modeled directly on the final part. I found out some aerospace OEM use “standard” geometries for these machining bodies i.e. they model specific pockets like 2.5/3-axis pockets, 5-axis pockets, etc which are then “combined” onto the model.
One advantage I see from this method is enforcing the manufacturability of the parts being designed. It might even be possible to accelerate the design/modeling process (and I guess some companies have implemented this) by creating a catalog/library of User-Defined features e.g. 2.5, 3, 5-axis pockets with proper geometry (fillets) and why not with fillets radius being automatically calculated depending on the pocket geometry (cutter tool diameter selection).
One drawback however might be the fact the machined part is modeled with an approach using “negatives” (removing material) while it might be interesting for designers to model the part based on functional specifications with positive features such as web, flanges, stiffeners, etc.
My concerns are about the ease of creating robust parametric models, where design/modeling can be accelerated through Knowledge-Based Engineering tools for example. I would like also to be able using “design in context” techniques such as using assembly skeletons where the geometry of the part is driven by external references to a skeleton part in the context of the assembly.
Within this framework, I don’t have for now a clear picture of what are the geometry inputs given to a designer when he starts a model and how far the automation of the design of machined parts can go e.g. modeling generic part templates. Also I am wondering if it’s possible to implement a digital continuity (re-use) between the models created during different design phases (different levels of maturity) e.g. a part being detailed from preliminary to detailed design.
As a side note I would like to mention a concrete example for the modeling of machined wing ribs I have seen from one aerospace OEM using wireframe geometries (basically a skeleton of flanges and stiffeners) as input elements. The machining pockets are still being modeled independently but are attached to the wireframe. It gave me the idea it could be combined with a methodology I have found in an open-access standard from the KÄRCHER company. It can be found at Link (under: Documents for Design Methodology >> Handbook for Methology). They call it the “Minus-Minus methodology” (pages 17 to 19). It is used here for molded parts but could be adapted for machined parts. The idea behind it would be to keep the concept of substracting machining volumes but building the model with positive features.
Sorry in advance for imperfect English. I hope my questions are not too vague and some of you will have some experience they can share.
Kind Regards,
faerosp
faerosp,
I am using SolidWorks on mostly non-aviation stuff. I have worked in the past on aircraft mounted appliances. My preference for modelling machined parts is to remove material from a blank. We need to be aware of how the part will be fabricated. Few of us here are machinists. When I add a pocket to a machined part, I can visualize the actual manufacturing process, and I can see most of the difficulties I am causing. I do want to minimize machining setups.
SolidWorks has a feature for adding ribs to pockets, which I have used on machined parts. This sounds equivalent to your wire-frame.
An important issue about modelling is how you manage tolerances. On a machined part, I prefer to model at nominal size, and apply tolerances by whatever method is clear and convient. I expect the machinists to read my drawings. If you go for moulding or 3D printing, the vendors rely on the STEP file you send out with the drawing, and everything should be modelled at median size. All of your features should be in the middle of their tolerance zones.
JHG
As drawoh has pointed out. Andit can get complex.
A manufacturing engineer or and sometimes a cnc programmer will look at the following.
What type of material
Heat treat how will it affect geometry eg distortion
Will it require steps to fabricate. Will stock need to be added, for post operations, or after
Heat treat, or allowance for plate, or the finishing surfaces require grinding which needs added stock. How much stock, any areas case harden
How much stock needs to be added.
The operations will also depend on complexity of
The milling turning, grinding , and more.
The capability and capacity of the factory.
And it's people.
After I think 18 or 20 years of solid modelling, I'd say 'whatever it takes' to get the net shape you need. I've been working a lot with castings lately. Generally with castings, weldments too, you make an as cast or as welded configuration, and model the machining steps that remove material in the as-machined configuration. One drawing uses the as cast config, one dwg uses the as machined config.
I believe on a new project do the best you can draw designs as preliminary. Send out for quotations and concurrent engineering.
And see what happens.
Shop review, manufacturing review , adjust or add modification and Then release.
My point in my first post there so many different
Products. A designer has to rely on the shop to get it done. And it perfectly acceptable to
Research manufacturing methods. The draw the pictures.
The manufacturing process matters a lot, for any machined part.
[ul]
[li]Manual or CNC?[/li]
[li]If CNC, is a 3-axis, 4, or 5-axis machine being used?[/li]
[li]How sophisticated is the G-code conversion software?[/li]
[li]And the operator?[/li]
[/ul]
Ever since getting my own CNC router, I have taken a number of parts from parametric CAD through G-code generation to operating the CNC machine. There are a LOT of steps and many of the later steps are NOT OBVIOUS at the start. If you can get some hands-on time with Fusion, MasterCAM or some other CAD to CNC conversion software and then feed it to the machine, too, you'll get the best education possible to answer your question.
my 2c ... the one thing that really annoys me is when designers lose track of the cutter axis and simply put the same fillet radius on all corners of a pocket (which is very easy to do in CAD, but makes the machining of the part a lot more expensive).
All fillet radii should be larger by some amount than the cutter to maintain a more uniform chip load and stop sniping into the corner. For USA it should never be a 0.250 or 0.281 radius; it should be 0.263 or some other off-increment value. Of course then manufacturing whines that they need a custom cutter diameter and if they get it then they complain about the cutter sniping in the corners. No good deed goes unpunished.
LOL but that's why fillet radius should have a liberal tolerance with a standard radius if it
Can be aceptable for stress.
Makes every one's life easier.
Yeah, but the CNC crew looks at that tolerance and says "we can get a nominal cutter" and boom chatter the corners to crap and overcut.
True the shop will push feeds and speeds, causing
Excessive force , equating to chatter, caused by vibration..
At my job I had them pull back the reins. And slow them down improving quality. I had authority to shut them down, if there was quality issues.
We would resolve the cnc program . To correct the situation. Preventing scrap or MRB review.
3DDave said:
All fillet radii should be larger by some amount than the cutter...
I was told by a machinist that they don't like to stop the cutter in corners. If you specify a 10mm corner radius, they will use a 16mm or 5/8in cutter, and program a cutting radius.
JHG
Thanks all for your answers.
Looking forward for more replies. Especially in the area of 3d modeling, my concerns being more related to modeling aspects rather than pure machining considerations. Indeed the subject of DFM design guidelines is well addressed in the technical literature.
Best Regards,
faerosp
With over forty years in the manufacturing field, I started with a slide rule and a drafting table. And it has been an incredible journey. What made a engineer was the ability to manually calculate and the ability to visually see a 3d object. And to learn to
anticipate the issues before it happens.
As a late bloomer with 3d cad. It has become a. Very valuable tool. Catch the errors before it happens. A to view a model in 3d is spectacular. Even this old g can appreciate that. Watching a lot educational videos as an engineer designing a new conventional model, and visualize were there is interference and I can obtain fast dimensional results.
That all said it's my opinion and this old g
That experience and 3d modeling go hand in hand. And smart phones are difficult to type.
My experience is from the industrial gas industry, mostly regarding the design of high pressure oxygen systems. Form follows function. If I need a part to be made in a particular way, it's for a reason. If the part can't be made with existing tools and methods, we make new tools that allows it to be made. If we need a special chamfering tool, we design it and make that too. Now of course you would combine that with extensive discussions with the operators in the shop to get input on how to reduce manufacturing costs; maybe a more sophisticated tool-holder, maybe a custom made cutter, new machine +++. (Shop review(s), manufacturing review(s) , adjust or add modification and then release is of course needed during the entire process; like mfgenggear states).
In short, find out what the function demands, and try your best to create the part. The cost can always be reduced in future iterations (if you are lucky). I have seen 50+ year old products with well over 15 revisions made to reduce manufacturing costs; revisions made over the years as the machining capabilities have improved across the board. Anyways, my five cents.
Thank you mfgenggear and Prometheus21 for these additional replies.
faerosp
