Set Font size and color in drawing table
sri91
IN
Hi Everyone,
I am trying to set the parameters 'Font size' and 'color' in the texts of a drawing table.
I am using the below code.
What ever the text size I give, it is taking zero(0).
Can you please suggest me.
drwTbls(drwTblNum).SetCellString rowCount, 2, wrksht.Cells(j, 1)
drwTbls(drwTblNum).SetCellAlignment rowCount, 2, CatTableMiddleCenter
Set currText = drwTbls(drwTblNum).GetCellObject(rowCount, 2)
currText.SetParameterOnSubString catFontSize, 0, 0, 0.075
Dim txtProps1 As DrawingTextProperties
Set txtProps1 = currText.TextProperties
currText.SetFontSize 0, 0, 0.095
currText.TextProperties.Color = vbGreen
Thanks in advance
SURYASRI
Hi Little,
Even though I have given the update, it is not setting the font size.
Still it is changing to zero only.
Please help.
drwTbls(drwTblNum).SetCellString rowCount, 5, Right(wrksht.Cells(j, 2), 5)
drwTbls(drwTblNum).SetCellAlignment rowCount, 5, CatTableMiddleCenter
Set currText = drwTbls(drwTblNum).GetCellObject(rowCount, 3)
Dim ifs As Double
ifs = 0.075
currText.SetFontSize 0, 0, ifs
colo = currText.TextProperties.Color
currText.TextProperties.Update
SURYASRI
Oh, as far as I remember you have to specify font not by size, but by it's index in dropdown menu as displayed in the UI: 1, 2, 3 etc.
Hi Little,
I am getting error for the below code.
Hi Little,
currText.TextProperties.Font 0, 0, 0.095
In the UI in catia text properties are in inches like 0.095, 0.075, 1.2 inch etc...
Please check the attached picture for the UI.
Please do the needful help.
SURYASRI
 https://files.engineering.com/getfile.aspx?folder=3661a123-461a-4422-99e4-499801cf70b4&file=Capture.JPG
