Ng2020
Aerospace
- Nov 6, 2020
- 184
I have been looking at hilok/hitigue usage across a number of different OEMs.
Regarding the basic Ti hiloks HL10,11,& 12, , I noticed that while HL10 is called out by several OEMs in shear applications, its equivalent tension head, the HL12, is not in common usage for tension applications
Is anyone aware of a good reason for this?
Alternatively, can anyone point to an example of HL12's in use by an OEM?
I noticed at least one OEM calls out HLT412 hitigues as their go-to hexdrive bolt for tension applications. My assumption is that for those joints requiring tension head hiloks, they are probably fatigue details, whose qualities would benefit from the hi-tigue hole fill factor...
