Rajeev Kulkarni
- Aug 1, 2024
- 1
Clause 6.3.6 specifies that ''MAWP shall be at least the maximum discharge pressure plus 10 % of the maximum differential pressure''.
My Question is:
For calculating ''maximum discharge pressure'' or ''maximum differential pressure'', do we need to consider the Shut Off head Test Tolerance provided in Table 16?
My understanding is that the 10% margin specified in Clause 6.3.6 takes care of the excursions and an additional Test Tolerance as per Table 16 is not required / applicable.
My Question is:
